Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
I can't restore/upgrade iOS
I have a paperweight! It's stuck in a boot loop. I was running 6.1.2 JB evasi0n. I tried to update to iOS 7 because I couldn't restore 6.1.2. Now, I get errors when trying to restore/update.
The whole point was to fix, what I thought was a software problem. After replacing the screen it just kept searching for signal. I tried changing the time/date. I replaced the antenna, the blue chip by the antenna is fine.
Please help.
Thanks,
Justin
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The best way it to take your phone into DFU mode (for this you can follow a YouTube tutorials) then restore and update it completely but please note in this way you may lose all of your data.
Esta resposta foi útil?
Pontuação 1
1 comentário:
David - How about adding a link to the YouTube video you think is the best to explain this.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 130
