Ir para o conteúdo principal
Guides and repair information for the 4th generation of the BMW 7 Series / E65, E66, E67, and E68 platforms.
23 Perguntas Visualizar todos
passenger rear side tire seems to wear unevenly
the rear tire on the passenger side wears more than the driver side
Esta é uma boa pergunta?
Pontuação -1
1 comentário
I second this! Just got my second rear passenger side tire in less than 7.5K miles. I also have off-setting front and rear tires and the back rear passenger tire seems to rub on the outer side of the wheel well. Getting an alignment and will let you know if things get any better.
por
Adicionar um comentário
1 resposta
Solução escolhida
BMW tires normally wear a lot more on the inside than on the outer edges, because of the way the suspension is set up.
You probably need an alignment, or something is bent in the suspension. Posting pictures may give us a better idea.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
al bettencourt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,194
