Ir para o conteúdo principal
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
160 Perguntas Visualizar todos
Broken Headphone tip stuck inside PS vita
So my headphone jack broke inside my ps vita, i have tried getting it out with a pair of pliers and small objects to no luck. should I go about opening it?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
The headphone jack is connected directly to the motherboard, and there is no way to remove it without soldering (reference: here and here)
I've read that getting a very small drill bit (#76) and applying some slight side pressure and flicking out may work.
I've also personally had limited success (read: one time) of very carefully and VERY gingerly drilling out the middle of a broken-off headphone jack with a tiny drill bit, then extracting with dentist tools. I'm not suggesting this as the BEST course of action, but it is possible. If you attempt, make sure you have a way to secure things so they don't move about when you're drilling. (A vise with soft pads perhaps) and be careful.
Cheers!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Sebastian Mundo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 656
