Ir para o conteúdo principal
Released September 14, 2012, Apple's EarPod headphones are a new revision to their iconic white headphones. Model number: MNHF2AM/A.
59 Perguntas Visualizar todos
Left Earpod Has No Bass and Sounds different from the right
What has happened? the Earpod is quieter, and distorts the audio. It was hanging from my shirt, and then i put it in my ear and then this happened.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Look down in your connector slot with a flashlight to see if a small piece of debris is causing a bad connection. Blow it out or rub it with rubbing alcohol gently to clean the plug in while holding it upside down so the alcohol runs back out if any try's to run
Esta resposta foi útil?
Pontuação 1
1 comentário:
What is a connector slot and where is it?
por
Adicionar a sua resposta
Colby Johnson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 9,417
