cycle lights blink washer will not run
washer will not run . no codes, cycle light will blink once when start is pushed
Esta é uma boa pergunta?
Cancelar
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Rep: 1
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa LojaUnplug it for 5 minutes to allow it to reset then plug it back in and see if it gives you any codes.
Rep: 1
the door lock light didn't come on. when I unplugged the electric and plugged it back in the door light came on. it ran thru a couple minutes then shut off when the door light went out. can you help me? thank you.
fred
Rep: 1
when i put a load in it starts and then stops and the light start blinking and i have to move the cloths around in the drum - or take some cloths out - but that only works sometimes.
Rep: 1
Washer stopped with twelve minutes left on the timer clothes are dry enough to take out.the washer will not restart. I unpluged the machine for five minutes and when plugged back in no code appeared. When it was plugged back in a real low hum could be heard but still will not do anything
Rep: 1
After turning power on I push the start button and hear a humming noise. Please help
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Todo: 1,311
