cant get the indoor / outdoor antenna to work
I have a Mitsubishi WD73734, I hooked up the indoor / outdoor antenna went through the steps and I still get nothing
Esta é uma boa pergunta?
Depending on where you are located you might not get any over the air signals.
Do you or a neighbor have a working setup on a different TV? If you do thats a good sign.
Check your settings in your sets configuration menu make sure its correctly setup
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 119
1 comentário
What does not work? does it work with Video i.e. DVD etc?
por oldturkey03
