power on only after pressing more times the power button
I had some power failure in my home but even if I have an UPS APC CS 500 my iMac powered off. Now when I try to power on my iMac I need to push more times the power botton before it goes on. I have an USB HUB that have a LED from which I can understand if there is tension.
The LED rapidly flash when I press the power button so it is as if the tension passed, and then went out quickly...only after many times the LED light on and iMac start.
What can I do?
My iMac is new (January 2013), thank you. Dario
Esta é uma boa pergunta?
2 comentários
Dario, " (January 2013)" have you spoken to Apple yet? This should be covered under warranty.
por oldturkey03
Dario - I agree with OT here you should start with Apple. Don't go into detail of your power failure with them, but do tell them you had your system plugged into a UPS and telling them the brand & model (APC CS500). I doubt the UPS failed you here, just odd timing. I use APC units (over 50 units) and have not encountered any failures like yours with a good hand full of brownouts, power outages & lightning hits.
por Dan
