Mac only types in caps
Anyone know how to fix this and yes, caps is off but still types in caps. I went to system preferences and it looks right. any suggestions
Esta é uma boa pergunta?
²naythan
it would always be a great idea to start a new question for that matter.
anyhow - first of all - use your setup disk to remove the password (use this guide (click))
after the system restarted, try to kill the caps lock function, i only guessed this - but maybe the mac "thinks" he had received the caps lock code from the keyboard (keyboards are working with codes)
use this guide (click) to try it
Esta resposta foi útil?
+ links
to kill the caps lock function: https://www.maketecheasier.com/disable-c...
did you try to reboot your MacBook ?
i've read that sometimes this could happen and the problem was gone after a reboot.
if a reboot won't fix it - what happen if you switch caps lock on ?
I rebooted about 20 times and nothing, when the caps is lit still types in caps..
I tried both of your suggestions, didnt work. Im assuming its the keyboard..thank you for trying
to bad - maybe you should try a usb or bluetooth keyboard before you go out and buy a new topcase
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 16,568
