How can I assort all the screws of my iPhone 5?
Ok here is my problem. Ive bought an used iPhone 5, with some screws missing. So of course I want to replace those missing screws and bought a package with all the 54 iPhone 5 screws. Does anyone got any idea how I can easily find out which srew has to be add where? I started with assorting the bigger ones, but below 2,5mm its very difficult to see a difference between the srews. Is there maybe a complete overview or model of all iPhone 5 screws? Thanks in advance!
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
3 Soluções
Solução escolhida
I went through this with a 4s where all the screws from two phones got mixed up when a table was bumped. In my case, I bought a set of screws for baseline comparison.
I took a sheet of paper and drew squares, looked at the repair guide, and wrote in each square a size and number of screws. Last, I used a micrometer to measure each screw and place it on/in the square on a piece of paper.
Later, I used a little plastic (think fishing lure holder) clear box and labeled each compartment where I placed screws from a couple extra sets that I had ordered -- never know when you might lose one.
It takes a bit of time but better than shooting in the dark.
Esta resposta foi útil?
Pontuação 4
If you go through the iPhone 5 guide list and follow each guide for the areas where the screws are missing, the guide tells you what size each screw should be, a micrometer but be needed.
iPhone 5 Repair
Just work through it one be one and you will get there, an important thing to note, if at any time there is a little too much tension on the screw STOP as this will be the wrong screw.
Please let me know how you get on.
Cheers
Brendan Mills
Pontuação 1
Comentários:
Thats what I tried first, does the guide tell me the length or the size of the screw?
por
Yes it does, every screw will have a size stated in the guide
por
Same happened to me dropped all of them
Pontuação 0
Adicionar a sua resposta
Rob será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Todo: 11,367
