Ir para o conteúdo principal
Tudo que você precisa para reparar por conta própria o seu iPhone! A iFixit tem guias de reparo gratuitos e informações de desmontagem para cada um dos modelos iPhone, assim como as melhores peças de reposição e ferramentas da galáxia!
36444 Perguntas Visualizar todos
Pergunta encerrada
My iPhone switched itself off and doesn't start up again
Hi there,
my iPhone switched itself off and now I can't get it to power up again. Do you have any sugestions what the cause may be and how to repair it?
Cheers
Christian
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
does it react in any way when you try plug it to a computer/power supply ?
Esta resposta foi útil?
Pontuação 0
1 comentário:
nope, it didn't react in any way - dead as a door nail. However the support people of the place I bought the phone from suggested to connect it to iTunes and than to simultaneously press the menu key and the on/off button. They said that iTunes will eventually recognise the phone in repair mode and so will the phone itself. Well I followed those instructions and it worked. The phone is back up and running and without any loss of data
por
it might have something to do with the battery connection. Might test it out with a new battery to see if that's the case.
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 682
