Ir para o conteúdo principal
A linha de laptops MacBook Pro da Apple foi concebida para usuários avançados e profissionais. Atualmente, a linha MacBook Pro inclui as variantes de 13, 14, 15, 16 e 17 polegadas, com revisões maiores definidas pelos designs Pré-monobloco (original), monobloco, tela Retina, Touch Bar e SOC (system-on-a-chip).
19983 Perguntas Visualizar todos
MBP 15" late 2008, MBP 13" Early 2011 keyboard swap?
I have an International English (vertical Enter key) MacBook Pro 15" Late 2008, and my girlfriend has an Early 2011 MacBook Pro 13" with a German keyboard, with a keyboard with the same shape keys. Our needs have changed, and we are considering switching computers, but we each want to retain our keyboard.
Being reasonably handy and careful, and having access to the right tools, would it work to simply switch the two keyboards?
Esta é uma boa pergunta?
Pontuação -1
1 comentário
This question was migrated from http://meta.ifixit.com/Answers.
por
Adicionar um comentário
2 respostas
Solução escolhida
Sorry no they are very different internally.
Esta resposta foi útil?
Pontuação 0
If both Macbook's were 15" or 13" then you could swap them, provided the layouts match. You can't swap a 15" for a 13" keyboard or vice versa, as the keyboard connector is in different places.
Pontuação 0
1 comentário:
Up to a point ... Not all 15" keyboards are interchangeable. But it turns out, so far the 13" models are. The only rub with this is some keyboards are secured with rivets vs screws or a combo of both! The metal plate is different between each of these.
por
Adicionar a sua resposta
CarstenW será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 241
