How did I brick my phone after replacing screen, power ribbon,battery?
Hey there, I tried replacing my screen, rear panel, power and sensor ribbon and also my battery. I have double checked all my connections, but it doesn't seem to matter. My phone will not power up, will not vibrate and will not be recognized by a computer. The only signs of life are when it's plugged in it seems to get warm like it's charging normally. What would cause complete power loss?
Esta é uma boa pergunta?
Someone help please! I don't want to have to go buy a new iPhone 5.
por Bob
Did it work before you did all those replacement? why did you replace all of that?
por oldturkey03
It all worked technically. The screen was cracked but worked. The power button worked, but would not "click" and the battery worked, but it only lasted a few hours.
por Bob
Sounds to me like there may be damage to the motherboard. If you have tried a new battery and tried the old battery as well to make sure its not an issue with that. The only other thing I could think to change out would be the charge dock and see if that changes anything.
Good luck buddy
por gizmo4sal3
Yea, I tried both batteries and got the same thing. How do you damage the motherboard? I was pretty careful in disassembly and there doesn't appear to be any external damage. Could it be something with the power button ribbon? Is there a ground for the power system that maybe I'm not getting a good connection on?
por Bob
Exibir mais 4 comentários
