Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Will iPhone 4 turn on if Dock flex cable is disconnected
With the iPhone turned off.
If you have a working iPhone 4 and you take off the back glass and disconnect the dock flex cable from the motherboard and the battery is fully connected and charged.
Will the iPhone turn on if you push the power button?
I realize that you cannot plug in the usb or charger because the cable is disconnected.
I don't have a iPhone 4 or I would try it myself.
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Austin, Dustin thanks for the quick answers.
I was trouble shooting a no turn on issue after changing the screen.
I unplugged the battery and reconnected it and then it turned on and everything was o.k.
por
Adicionar um comentário
2 respostas
Solução escolhida
The answer is yes it can. But the answer is also no, depending on other damage or faulty parts.
With 3G/3GS, if the dock was bad, it was more likely (90% of the time) that the phone wouldn't power on.
No matter if it works or not, I wouldn't risk possible further damage by a circuit short if it does or you could get it to power on with issue you've mentioned.
Esta resposta foi útil?
Pontuação 0
Yes it should be able to turn on. I just tried on mine and it powered up successfully.
Pontuação 0
Adicionar a sua resposta
Joe in PA será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 146
