Ir para o conteúdo principal
Second generation of the Ford Focus.
95 Perguntas Visualizar todos
a/c freon fill location 2005 ford focus
cannot locate the low side refill port
Esta é uma boa pergunta?
Pontuação 5
2 comentários
are we dealing with the European version or the north American version
por
It would be a little better to say; in front of the working linkage; on the right side of the vehicle.
por
Adicionar um comentário
5 respostas
Solução escolhida
Eugene Scarbrough, The service valve is behind the wheel well cover on the front passenger side. Take a look on here for service and refill instructions. "the A/C system is under high pressure. Also, while R134a isn't as bad for the environment as the older R12, there is still a heavy fine for venting R134a into the atmosphere. You should never take apart your A/C system without proper training and refrigerant recovery equipment. Wear protective glasses at all times while servicing your A/C. Also, you will be working under or near the car while it is running. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 9
5 comentários:
@oldturkey03 Congratulations on the milestone 300k just noticed your over
por
@jimfixer thanks appreciate it. Almost time to retire :-)
por
This is exactly where it is on mine.
por
@oldturkey03 - Congratulation also, You can't retire till after I do ;-)
por
@mayer darn mayer we'll be hanging out here forever. ;-)
por
Go to youtube.com , type in refill car air conditioner and watch the very helpful videos. Worked for me.
Pontuação 2
I'm sorry,you are wrong.The low side A/C port is behind the "inner fender"
of the right side or pass side.If you remove the "right front" tire and
fold back the "inner fender"from the front you will see the "accumulater"
and the low side port is easy to see on the top of the accumulater.A/C
gauges are needed to make sure the pressures are normal.Better yet let a
professional do it as you could causer more harm if you don't understand
and know what you are doing.
Pontuação 1
4 comentários:
Dead on right info. AC just needed a little shot, back to ice old.
por
Harry Grace, sure sounds like the same place as mentioned in my original answer.
por
IS The Accumulator in the same place on Australian Ford Focus since there RHD ?
por
That's actually called the low-side liquid receiver to prevent liquid refrigerant* flowing back to the compressor - liquids can't be compressed.
*: It's called "refrigerant" - there's actually no such thing as "freon". Freon(TM) is a trade name of DuPont for it's line of halogenated hydrocarbon refrigerants.
por
Low side a/c port location directly in front of pass side back left small valve can't miss it well it is on the 2006 Titanium model !!!
Pontuação 0
is the low side charging port in the same place on a Australian Ford Focus RS model?
Pontuação 0
Adicionar a sua resposta
Eugene Scarbrough será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 48
Duração total: 72,015
