Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
Won't recongize, read or charge battery, just shows black X.
Hey guys,
I bought a used MacBook Pro 13" Unibody and after putting a new HD and loading up Snow Leopard it runs great.
However it will not recongize the battery. It came with 2 batteries and would not read either of them. My initial theory was well both batteries are dead, so I bought a brand new one.
Still the same thing, it didn't read. Then I did a little detective work and found the battery connector was broken and missing one of the side tabs and a pin.
I thought once I replaced that everything would be good but it was not to be. I reset the PRAM and SMU and that didn't help either.
When replacing the battery connector I noticed evidence of a liquid spill, looked like coffee, it was dark and sticky.
I went ahead and removed the logic board and inspected it and found a few spots that were sticky and cleaned them with alohocol swabs and put it all back together.
Looks like all fingers are pointing to the logic board but before I send it off to a great little shop in Florida for repair I wanted to ask if anyone can think of anything else I may have missed.
As I said the MacBook runs great off power but won't do anything off a battery.
I have the initial 2 and the new one and still can't get it to do anything.
I just don't want to spend $250 on a Logic Board repair when it could be something else I'm overlooking.
Any insight on this from anyone? I think I covered all my bases on troubleshooting but it never hurts to ask for additional help.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Solução escolhida
You did everything that was possible to troubleshoot your battery issue. Last thing I would try is to clean the connecting battery socket on the logic board with electronics fluid cleaner and a tooth brush. If that doesn't work then you'll have to pay for a repair job.
Esta resposta foi útil?
Pontuação 2
1 comentário:
+ Ralph
por
Thanks for the reply, I'll try cleaning the circuit connection I never thought to do that. I didn't notice anything on the original connector though when I pull it out of the socket, but it can't hurt to try.
Once again thanks!
Pontuação 0
how to check if battery is ok? I have got macbook without charger and tryed to check with multimeter voltage at battery connector. I think, I need to close some pins to run battery, isnt?
Thanks
Pontuação 0
Adicionar a sua resposta
djmadness será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 2,823
