Touch screen chip replacement on logic board
Can the touch screen ic chip on the phone be replaced by one's self and what is the method? What is the repercussion if you mess up?
Esta é uma boa pergunta?
VitaminH, I do not think that it is possible for the normal DIY'er to replace the IC. You better have the right tools to solder an IC to a logic board, a good magnifier and a very steady hand to even try to attempt this. You better be a pro at soldering....the repercussions would be a logic board that turned into a pretty paper weight.
Esta resposta foi útil?
and it might not be the chip that needs replacing??
I have that problem... may I know your answer machead3 please?
Please start your own Question - This one has not been answered in almost 1/4yr!. Only Answers belong here.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,195
1 comentário
I noticed you never got an answer to this. Are you still having this problem?
por originalmachead
