Ir para o conteúdo principal
Can I change the logic board by a A1212 one?
Hi,
The logic boardof my MacBook Pro A1261 (17 inch Late 2008 with 2,5Ghz) is down... Do you think it's possible to replace it by the A1212's logic board board (which got less power but is also less expensive)??
Thank you all
Esta pergunta é pertinente?
Pontuação -1
Adicionar um comentário
1 Resposta
Solução escolhida
Unfortunately, Apple changed the connector type for almost all the connectors of the A1261 machines, so it's not a straight swap. You'd need to switch out most of the major components to do so. Sorry!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
cesbrongaetan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,714
