Ir para o conteúdo principal
My xbox 360 (newer version) won't turn on?
I mean look, I plug it in and when I touch the power button it makes the beep turning on sound but it stays off. Same with the disk input. I don't use HDMI I use the vid 2 for the TV.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi, it might be that the cables are faulty. Can u see the xbox showing the green rings? An hdmi cable is not that costly now, so see if u can get one and test with hdmi. Write back on what u did. Good luck.
Esta resposta foi útil?
Pontuação 2
2 comentários:
It doesn't show any green rings, and I'll try to get an hdmi cable as soon as I can. I'll get back to you when I try it out
por
It didn't work with the cable so I had to go send it in for repairs. Apparently somehow it was wet on the inside? (sorry for the late answer)
por
Common issue with "no power" is a usb port has bent pin and grounding. Visually check your Xbox 360 USB ports. None of the center pins should be touching the casing or outer area.
Pontuação 1
1 comentário:
All USB Ports are fine, but I've noticed that after I plug in the power and disconnect it there is a delay in the power box.....anything about that?
por
Adicionar a sua resposta
Johnny será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 4,394
