Pular para o conteúdo principal
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1961 Perguntas Ver todas
iPhone 3GS missing components
L85_RF AND L3_RF missing please what do I do?
Thanks
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
4 Soluções
Solução escolhida
Jaywn, there is absolutely no reason to replace the board. L85_RF is the "blue inductor" 1.2NH-1.36A-0.045OHM and as you probably already know, some people do bridge it by using a circuitwriter pen or similar tool. L3_RF is another inductor, values7.5NH-1.4A-0.080OHM. I would replace both of these components. They are readily available, but a bit hard to solder to the board due to their size. You'll need good tools and excellent skills. Both of the inductors are part of the cellular antenna circuit, your phone will not have any service without them. Total cost for both pieces should be less than $5.00, hope this helps,
Esta resposta foi útil?
Pontuação 0
Comentários:
Thank you. Do you know where I can find these parts?
por
It depends on where you are located. I would start with mouser .com or digikey.com. Thank you for accepting my answer.
por
If the phone works, do nothing. If it does not work, replace the logic board.
Pontuação 0
Comentários:
Hi. It just searches. Where can I find the L85_RF component or can I just bridge across?
Thanks
por
http://forum.gsmhosting.com/vbb/f631/3gs...
Here its the solution!
Pontuação 0
Comentários:
Same as in the original answer
por
Yes, is possible in Mouser-DigiKey,etc. Cost about £ 0.010 the spares and £ 15 for shipping + VAT.
Pontuação 0
Adicionar a sua resposta
Jaywn será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 308
