Ir para o conteúdo principal
Released in October 2011. GoPro's second generation outdoor camcorder used by professional athletes, sports enthusiasts, and core enthusiasts.
19 Perguntas Visualizar todos
Charging and power problem
Hi, my camra wont turn on and when i charge it dosnt show the red light dosnt shine, only if i take out and in the batery will the red light shine but when i try to power up det camera the red light stops shining and nothing happens.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
I'm suspicious that there's an internal battery that dies and then the GoPro's clock and OS stop functioning, regardless of the external battery's charge. Watch this video http://www.youtube.com/watch?feature=pla...
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Hi, have you solved the problem replacing the battery?
Do you know the nominal voltage of this battery? I have the same problem here!
Pontuação 1
Replace the battery.
Pontuação 0
Adicionar a sua resposta
Mike será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 8,904
