Ir para o conteúdo principal
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Perguntas Visualizar todos
How do you repair or replace ethernet port?
I have a first generation PS3 and there is no internet connection upon connecting an ethernet straight from my router. I have tried all troubleshooting of it being a router/internet issue. I believe the ethernet connector itself is loose or broken. I need a guide on how to replace the port. I tried local shops and they don't know how to fix it.
Esta é uma boa pergunta?
Pontuação 3
2 comentários:
Very first question I would ask you, is if you have soldered on a logic board before? I had a difficult time with the USB port re-soldering. I found that the solder used by the manufacturer seemed to be difficult to melt. You will need a good soldering iron/station and some good skills to get this done.
por
If I have a guide I can do anything. I have soldered audio equipment before amps and subwoofer wiring etc.
por
Adicionar um comentário
1 resposta
You need to dismantle it to the logic board, then use a desoldering braid to remove the soldered connections of the ethernet jack, then put a new one in.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jacob será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 14
Duração total: 3,350
