Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
3037 Perguntas Visualizar todos
Do you really have to remove the battery to replace rear camera?
I have ordered a replacement 4S rear camera which will hopefully fix my 4S. In reviewing iFixit and other tutorials for the repair, all mention first removing the battery before proceeding.
Is this actually necessary? The battery doesn't seem to physically obstruct anything with the camera replacement. Perhaps it is necessary to cut power to the phone components?
Thanks,
Steve
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Not necessary. Apple Technician Guide for iphone 4 has the correct procedure. battery is not removed. Actually, the battery MUST NOT be removed for safety reasons. once the battery is removed it MUST NOT be reused. So ifixit disregarded safety warnings, again.
Esta resposta foi útil?
Pontuação 1
Pergunta Mais Útil
it's for safety, you don't physically have to. but you dont want to short cut anything else
Pontuação 1
Comentários:
Thanks for the reply iwillfix, that makes sense to me. When you pull the EMI shield, it's probably easy to short something on the board.
I guess you could also just pop the battery connector up and disconnect the power only. Removing the battery is no big deal, but I figured if my battery happens to be glued down really well then I could avoid prying it off.
por
Adicionar a sua resposta
madmaxmedia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 148
