Ir para o conteúdo principal
Released in 2007, identified by model number WD-57734.
16 Perguntas Visualizar todos
Projection shows black & white flakes?
Projection image shows flakes when viewing. Flakes increase every on/off cycle. Almost unviewable. Any suggestions?
Esta pergunta é pertinente?
Pontuação -1
2 comentários
Thank you, very helpful. Once i gained acces from side panel only thig left was projection. A relief to know
por
You are welcome and hopefully you will get it fixed.
por
Adicionar um comentário
1 Resposta
Solução escolhida
PWILLIAMS, sounds like your DLP chip is failing. It literally has thousands of tiny mirrors on it and each "flake " you see is a mirror failing. This is a known problem for this model and Mitsubishi had at one time a program, to cover 1/2 half of the repair cost. You may want to contact them on here. If not, then use this guide to replace this chip. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
PWILLIAMS será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 458
