Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3302 Perguntas Visualizar todos
iPhone 4 network searching.No Network
Hello just like to ask.
Could this iPhone 4 logic board get fixed.The phone is not blocked but just seems to show network searching and can't pick up a signal.
I think there could be a problem here no to sure tho.
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 2
Comentários:
Yes them 2 chips are not on.I have them tho can take them of a spear board i have.Hmm now just need the soldering skills
por
Your image is a bit out of focus, but it does look like somebody applied a jumper. Remember that this ha now become common practice. You can get a circuit writer pen to close the loop if you have trouble soldering those very small pieces.
por
Adicionar um comentário
The Essential Toolkit
The most helpful tools in our most compact kit.
Comprar agora
Comprar agora
4 respostas
Solução escolhida
Your antenna coil is disappeared. If you replace it you will most likely have full signal again.
http://www.ebay.nl/itm/Apple-iPhone-4-Bl...
Esta resposta foi útil?
Pontuação 0
Pergunta Mais Útil
i have the same problem with iphone 4s simfree , he read the simcard but away searching.... any sugestion?
Pontuação 1
iphone 4s network searching poblam
Pontuação 1
make sure your time and date is correct that will fix it unless the black service wire is faulty or the clip is goes into is broken
Pontuação 0
Comentários:
Thanks did the time and date still not working.Wire is fine.I been looking at a few pics and it seems am missing the blue coil
por
Adicionar a sua resposta
Hal será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 21
Duração total: 25,662
