Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Perguntas Visualizar todos
Why won't my iPod turn back on?
I just finished replacing the battery in my ipod touch 4G and it won't turn on. I've noticed that the board above the battery, below the front camera is slightly warm. No cables are ripped/broken. Anyone have an idea what could be wrong ? I also followed the ifixit guide on how to replace the battery to the word...
Esta é uma boa pergunta?
Pontuação -1
5 comentários
What was the original reason that you replaced the battery?
por
I replaced it because the battery life was very poor.
por
Will it not turn on if you plug it into the wall?
por
Nope. Wall or computer, it won't turn on.
por
The board is now cold. instead of warm.
por
Adicionar um comentário
1 resposta
Solução escolhida
Here's a tutorial with pics that everyone has been requesting. I've used this method over a dozen times successfully. Good Luck!!
There are 3 small battery terminals (shown below). You only want to touch the one to the far right (circled below). Avoid touching the other 2 terminals!!
see the pics
http://guide-images.ifixit.net/igi/YiaQu...
http://guide-images.ifixit.net/igi/AnevP...
Esta resposta foi útil?
Pontuação 1
3 comentários:
thing you should always do b4 a screen replacement is make sure itunes detects it!
por
Thanks you sooo much!
This worked! ! ! ! My ipod is working again !
Only downside is that there's a small white line going across the bottom of my screen(Most likely has nothing to do with the battery ) buy HEY I'm not complaining ! :-)
Thanks again !
por
thats fantasic the white line im sure is a fault in the screen
por
Adicionar a sua resposta
Creativemagic será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 245
