Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Perguntas Visualizar todos
Buttons don't work consistently
The menu button and centre button have stopped working, I've opened is up and gave it a serious cleaning but there's been no change. This is the second Ipod classic that I've had this issue with. Last time it was the 'next' button.
Esta é uma boa pergunta?
Pontuação -1
2 comentários
Which model iPod is it? What did you do the Last time it was the 'next' button."
por
The ipod I had before this one, where the 'next' button stopped working, I bought a new one.
They both were 6th generation.
por
Adicionar um comentário
2 respostas
Solução escolhida
If you look at he logic board where the buttons are there's a yellow tape with a black tape on top.
Remove the yellow tape slightly to expose the metal contact (one piece will be stuck to the tape the other will be soldered to the board.
Make sure that the golden contacts on the logic board are clean corrosion free
With the metal exposed underneath the yellow tape you will probably need to scratch it a little bit and wipe it with your finger.
Put the tape with the metal contact back to how it was.
Repeat for the buttons not working.
It should work after you clean them.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Tried it out, worked great! There didn't seem to but much build up on the contacts, but a little rubbing alcohol and a q-tip worked great on the contact and on the con-caved button the makes the contact.
por
Pontuação 0
Adicionar a sua resposta
andrew será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 153
