Ir para o conteúdo principal
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 Perguntas Visualizar todos
What kind of accelerometer is present in HTC One
Is it possible to know the brand of the accelerometer as well as its specifications?
I believe that it might be an Invensense but what model is it ?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Raul, this is from a database that I come up with:
Name BOSCH BMA250 3-axis Accelerometer
Type name Accelerometer
Type 1
Vendor BOSCH
Version 1
Power 0.1 mA
Resolution 0.038307227 SU
Maximum range 39.2266 SU
Here is the datasheet for it. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Where is that database located? I'm trying to compare accelerometers between phones.
por
Adicionar a sua resposta
Raul será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,898
