Ir para o conteúdo principal
2.26 or 2.4 GHz / White plastic unibody enclosure
646 Perguntas Visualizar todos
Pergunta encerrada
I think my multi-touch trackpad has sunk?
Hi
my MacBooks trackpad has sunk...twice... and i think its got to do with a bracket or some structure that keeps failing.... any ideas
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
possible is almost everything
Teardown
look at step 7 - thats where you can see the trackpad - warranty ??
Esta resposta foi útil?
Pontuação 2
1 comentário:
There is a screw on the underside that is responsible for depth, as well as two small brackets that hold it in place. Definitely take it in to an Apple store to get them to fix it, as it is still under warranty. If they won't, use the link provided by Markus Weihler to tear it down to step 7 and check out those brackets and the depth screw.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 4,098
