Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2396 Perguntas Visualizar todos
How do I fix iPhone 4 'Error 2001'?
Hello, my iPhone 4 went into recovery mode after the Apple logo kept going on and off but would not boot up fully. I get the plug into iTunes logo and when I go into iTunes to restore it, it gives me 'Error 2001'. I just called Apple and they said it is a hardware issue. It is not under warranty anymore. What part could be causing this?
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
8 respostas
Pergunta mais útil
Based on the information found here, it sounds like replacing the battery wil solve the problem for you, and you can find those batteries right here.
Imagem de iPhone 4 Battery
Produto
iPhone 4 Battery
$11.99
Esta resposta foi útil?
Pontuação 5
2 comentários:
replacing the battery worked for me! i had the exact same issue. Thanks!!!!
por
worked for me also! Cheers!!
por
Replacing the battery not work for me, any suggestion??
Pontuação 0
1 comentário:
Hi,
I am having the same problem! Did you ever find a solution?
Thanks
por
I have moved the whole logic board to a different chassi and I still get 2001 error
Pontuação 0
This problem is probably related to the battery. I had the same problem, when I unplug the phone, it stops working. I also had this error 2001 when trying to restore my 4s.
Pontuação 0
100% best solution!!
It is due to battery, but no need of replacement...
Yes, just ask in any mobile shop to put charge to your battery externally..
Now try inserting battery and restore will be successful!
Enjoyyy!!!
Pontuação 0
Is there anyway to charge the batter at homes without going to a shop? (I have the same problem)
Pontuação 0
1 comentário:
i'm sorry, with our cable it won't be charged. So please try to charge your battery in any other way. The only thing is to charge your battery... do not pay for any new battery.
por
You're the only person that has to do that
Pontuação 0
1 comentário:
The best way for my family to come out and get my hair is done
por
How to Connet network of sprint
Pontuação 0
Adicionar a sua resposta
Josh K será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 16,280
