Fix the wifi issue?
Go to Device Manager and look at Network adapters to solve that problem how that will work???
Thanks
Esta é uma boa pergunta?
Thanks
Simple thing would be to check that it hasn't been disabled with the FN+2 key toggle if it was working before. Other than that I need more info.
Esta resposta foi útil?
Apparently seems like your W-LAN card is either disabled from your network connections or may be there is some hard switch which turned off. All you need to go open network and sharing center then click view network connection to make sure that you Wireless connection is not disabled in any case it should have to be enabled.
Other way is to check on your keyboard from top F1 to F12 keys if you can see a Antenna sign on any of key then press that key by pressing Fn key together.
If the problem still persist then I would recommend you to go on your manufacturer`s website to download the latest driver and update your driver.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,790
1 comentário
Does it show in Device Manager? Has it ever worked? Do you have a WiFi capabilities with this computer? You need to give us a bit more information.
por oldturkey03
