headphone jack repair
How do I fix a broken headphone jack?
Esta é uma boa pergunta?
You dont have to replace the whole logic board. Just buy the headphone jack itself. You will just have to solder just 4 points. However make sure that it is soldered just right and sit flushed. It's a little easier that having to replace the whole logic board and cheaper. Hope this helps you.
Esta resposta foi útil?
The jack is part of the logic board, soldered to it with 4 contacts. Replacement is usually by replacing the entire logic board. I would do a physical inspection and make sure it's not something that can be fixed (jammed contact inside of jack, or re-solderable contact) and if not, replace the logic board:
This webpage has tips and videos on how to repair your headphone jack: http://www.thefakegeek.com/2011/07/headp...
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 11,847
