Ir para o conteúdo principal
The iMac G3 came in tangerine, blueberry, lime, grape, and strawberry colors.
18 Perguntas Visualizar todos
Pergunta encerrada
Why won't the mouse work while the keyboard works?
Hi.
I recently got my hands on a neat iMac G3. While I was at it, I tried to install mac OS X leopard but it didn't work. So I just upgraded it to a newer version, mac OS 9.2, I think it was. After then my mouse has not worked while it did work before. Any clue what it the cause is and what I can do?
Thanks for answering while I'm at it :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
I will make the assumption you have a USB mouse plugged into the keyboard. Your computer will not run Leopard but should work well with 9.2. When you installed 9.2 did you format the drive? If not I would start over by formatting the drive and doing a fresh install. Ralph
Esta resposta foi útil?
Pontuação 0
1 comentário:
Checking Mactracker your computer will load Panther 10.3 which will give you many more options in software and more importantly in internet browsers. Ralph
por
Pergunta mais útil
It can't be done. Because I can't move the mouse. Do anyone know a shortcommand for formatting the harddrive? Probably eh.
Pontuação 1
3 comentários:
Open cd drive drawer and place system disk on tray--close tray. Power off by holding the power button until shutdown. Press the power button and the press the c on the keyboard and keep it pressed until the computer starts. Follow install instructions beginning with format the drive. This should clear your problem. Ralph
por
I'm including the guide page for your computer. Your hard drive is how big and is the first partition 8 GB or less? Ralph
iMac G3 Model M4984
por
I think it has less.
por
I've got my iMac 333 running fine on 10.4.11 with 512mb of RAM installed... Had to take out the hard drive and use another Mac to install it on that drive, due to 10.4 only coming on a DVD. But heck, I now have a scavenged DVD-ROM/CD-RW from a 550 Powerbook, running in there just fine. It can read and process data DVD's (such as installation disks), but the computer is not able to play DVD movies.
...and for 9.2, a quick browser is Classilla, which is basically a mobile browser which loads things very quickly... Thing of browsing the internet on your phone, but with a mouse, a real keyboard and decent-sized screen...
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,612
