Ir para o conteúdo principal
Model A1213 / 8, 16, or 32 GB capacity
216 Perguntas Visualizar todos
Pergunta encerrada
The sound is messed up
it sounds like the headphones are not plugged in all the way but they are. You can hear the music but not the words
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Since the audio
is digital it should be all or nothing... are you listening to a karaoke or instrumental track?
Remember to return and mark as accepted the answer that best solves your problem.
Good luck,
N
Esta resposta foi útil?
Pontuação 1
clean the jack. you can also try to use a very fine screwdriver or similar tool to carefully bend the outer connection a bit towards the plug...
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,448
