Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
The Nexus S is a smartphone co-developed by Google and Samsung was the first smartphone to use the Android 2.3 "Gingerbread" operating system.
35 Perguntas Visualizar todos
bad contact micro-usb charger attack
looking the micro welds they seems to be all right but they doesn't work...is it possible to weld againg them or it's necessary to change all the part of mother board where the chargar attack is attached?
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
Kevin Santi, yes you can reflow the existing solder with a small soldering iron. Test your jack with a multimeter. Plug it in and test on the motherboard contacts, to make sure that you have power on that end. Hope this helps, good luck
Esta resposta foi útil?
Pontuação 1
Comentários:
Thank you very much =D
por
Adicionar a sua resposta
Kevin Santi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 421
