Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
3038 Perguntas Visualizar todos
Sleep/wake button and digitizer not working after screen replacement
Ok folks, this is an iPhone 4S working on AT&T. Screen cracked. Bought a replacement, this one:
http://www.amazon.com/gp/product/B0068PR...
Replacement was uneventful (I've done it about 6 times in the past), used ifixit directions. No problems during repair from what I could tell.
When I get it all back together, I notice that 1) the sleep/wake button does nothing and 2) the digitizer doesn't work (i.e., the screen turns on fine with home button, but there's no touch response whatsoever).
I've tried restore via iTunes, seemed to work normally, but no change afterward. Running latest OS (6.1.2 is it?). Can't do a hard reset without a sleep/wake button.
Any help would be greatly appreciated! Thank you!
Respondido! View the answer Também tenho esse problema
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
2 respostas
Solução escolhida
As I see it three things could have happened:
1) You've damaged the power button flex cable. (Most likely)
2) The flex cable isn't properly connected.
3) You've damaged the logic board. (Let's hope not)
As for the digitizer, the digitizer flex cable has probably been damaged during install or you've received it faulty.
Esta resposta foi útil?
Pontuação 2
Comentários:
+ I'd go with "you've received it faulty"
por
Just wanted to bring some closure to this: I opened up the phone and realized that I had indeed ripped the digitizer ribbon. And the reason the power button wasn't working is that I hadn't connected the power button cable. Duh! Thanks for your help!
por
Here's a photo of the ripped digitizer ribbon cable. When they say to be careful, they aren't joking! :-)
Thanks again.
Pontuação 0
Comentários:
You're very welcome :)
por
Adicionar a sua resposta
Tim Davie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,406
