Lock Button not working after Digitizer Replacement
So i have changed the digitizer and soldered the connectors for the home button and digitizer.
Now when i press the lock button nothing happens unless i hold it and eventually it gives the option to turn off.
I noticed this question has been asked but at this moment there is no solution in that question:)
Many Thanks
Esta é uma boa pergunta?
I am having this exact same issue with an iPad 2. Tomorrow morning I am going to try a new cable to see if that fixes it. I will let you know.
por Caleb Baker
Hello, I have the same problem and wanted to ask if you figured out how to fix the problem after replacing the digitizer and home button after being soldered together. Thanks.
por Ivan
