When removing the battery I pierced the foil with the spudger.
Whilst removing the battery I pierced the foil with the spudger, can I still use the battery and can I repair this with anything.
THANKS
Esta é uma boa pergunta?
THANKS
Mike, I most certainly would not. If the battery's outer case is punctured, the lithium inside is highly volatile and can react violently with water, which includes humidity in the air. I would discard it properly and get a new battery
Esta resposta foi útil?
Thanks for the reply, I will dispose of this one then. Do you know where I could source a replacement.
Regards, Mike
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,855
