Ir para o conteúdo principal
Repair guides for the variations of the Compaq Presario CQ62 laptop. This brand was manufactured from 1993 to 2013, and was owned by HP from 2002 to 2013.
How do I restore my laptop to factory settings?
How do i restore my laptop to factory settings?
Esta é uma boa pergunta?
Pontuação 3
1 comentário
can i make a restore disk from this computer
por
Adicionar um comentário
4 respostas
Pergunta mais útil
mark, The HP Recovery Manager application, installed on the hard drive of HP Notebook PCs, can be used to recover the computer to its original operating condition. you will need a recovery disk for that, otherwise you loose your operating system. Here are the instructions. The Maintenance and Service Guide can be downloaded from here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
The "hard" way 'round isn't all that difficult either. I have a CQ62 that used to be my wife's (we bought matching notebooks... sweet, huh?) and when she "retired" it, I used it as an OS installation mule (Linux, Server '12, etc.)
Recently, My 6 year old daughter was complaining that the Barbie website was stuttering and slow on the computer I had her on. I gotta wonder whether Barbie has a backroom deal with the computer manufacturers to sell more new systems, but I digress...
You can still download a Win7 iso, or buy an installation media disk for a few bucks, and using the CoA on the bottom of the computer, have a nice, fresh install without any bloatware. Either plug it in via ethernet cable, or download the wireless driver on another machine and thumbdrive it over to the Compaq, and you can start downloading updates and drivers that way.
It takes a bit longer and a little more work, but I'm pleased with the performance of the v120 on 3GB of RAM with the clean installation.
Pontuação 1
Well it matters on what it is doing
Pontuação 1
shut down your computer (or laptop) then turn it back on and immediately start pressing f11 repeatably untill the recovery window then press restore and back your files up the continue and then it should work. if not then i dont know
Pontuação 0
Adicionar a sua resposta
mark será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 19,124
