Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
914 Perguntas Visualizar todos
Need to click home button many, many times for it to respond
My home button has been erratic for awhile, rarely requiring a second click before the iPod responds and takes me to my homescreen. Suddenly, the home button stopped working at all. Out of desperation, I decided to press on it again and again, and after 30 - 50 presses, it will bring me back to the homescreen. I hope I'm not further damaging my iPod! This iPod is only 4 months beyond the 1-year warranty, and I would rather not spend the $200 + that Apple estimated it would cost to send in and repair. Any suggestions??
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I found out that by using AssistiveTouch, under Settings, General, Accessibility, I can bypass the need for the home button for now. It gives me an on-screen button that gives me a home button when I need it. Thanks!
por
Adicionar um comentário
2 respostas
Solução escolhida
iPod Touch 4th Generation Home Button Ribbon Cable Replacement
Sounds like your issue, if you are technically proficient enough to do the work yourself, I suggest to open it up and make sure it is just not off center before purchasing a new controller.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you flogo2003. I appreciate your suggestion very much. I doubt I am technically proficient (or brave!) enough to try this myself, but now I will have more knowledge when I'm ready to go in for repair. I'm not yet sure what repair options I have. We have Apple stores and "Peachmac" in our area. I'm still researching my options. Thanks again.
por
On the ipod touch 4, there is a small switch that is glued/taped to the frame assembly. This part is very small, and inexpensive. However, it does require you to take apart the ipod to some degree. Once the front screen/lcd are removed, you will see a steel fram underneath. There are a number of screws that hold the frame down, they are NOT the same size, so make sure you keep track where they go.. There is a guide in the ipod repair section of this site that will show you how to do this.
If this is too big an adventure for you, you can always ask some of the guys on here if they can fix it for you, assuming there are no other problems. This is about a 35-40 min job for someone that knows what they are doing..
Pontuação 1
1 comentário:
Thank you for your input. I discovered how to use AssistiveTouch for now, which gives me a home button on the screen. Your info helps me know what to ask for when I'm ready. Thanks!
por
Adicionar a sua resposta
CLK23 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 306
