Ir para o conteúdo principal
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Perguntas Visualizar todos
Why my LCD screen has a single vertical pink line?
Why my lcd screen has single vertical pink line? It won't gone even though I has reset PRAM, wipe the screen pixel with hands.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Chan Ricky, vertical lines on any LCD usually indicate a failure of the LCD panel. There is also a small possibility that this is caused by a faulty video cable itself. So check on that first. Of course, also check on an external monitor and see if it shows the same line, then you narrowed it down to the video card portion of your computer. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Chan Ricky será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 3,474
