Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Perguntas Visualizar todos
Can I make a fusion drive in my iMac with OSX 10.8.2?
I see on Macworld how to make a fusion drive http://www.macworld.com/article/2014011/... but that is on a Mac mini 2012 and I want to know if I can do it in my iMac 21.5" EMC 2428 with Mac OSX 10.8.2 after I install a ssd on it
Esta é uma boa pergunta?
Pontuação 1
1 comentário
if you asked Apple they must suggest you to buy their new iMac LOL
por
Adicionar um comentário
3 respostas
Solução escolhida
Some people have had success with early Mac Mini's '11 Mac Mini Info. Yet, others have not been able to get a MBP working: '11 MBP info.
I suspect there is some firmware issues on some systems. Sadly Apple has not disclosed what systems work and which don't so you will have to just give it a try. Please do let us know if you were able to make it work.
Esta resposta foi útil?
Pontuação 1
I made it work with a 21.5 in. 2011 iMac with a Crucial 256 gb M4 SSD and stock 1 TB HD. I found instructions on the web using the Terminal program. I am running the latest OS and my machine screams now. I activated Trim Support using a shareware program. Even About My Mac recognizes it as a Fusion Drive.
Pontuação 0
1 comentário:
Your correct! Most any Mac can be configured with a Fusion drive using the terminal commands in OS-X Mountain Lion. When I wrote the above answer we didn't know about how systems that didn't have the BIOS support could be setup.
por
I can confirm this, i've been using / upgrading (up to 10.9.1) my 21.5 mid 2011 imac without any problem with a fusion drive made from terminal commands, the stock 500Go HD and a vertex 3 SSD.
Absolutely nothing to say except it rocks !
Pontuação 0
Adicionar a sua resposta
jimenezser será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,408
