Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
Why is my display screen in black and white only?
I resently replaced my broken touch screen....since I put the phone back together I only get black and white images on my screen .... All buttons, apps and screen work perfectly... I just don't have any color.
Esta é uma boa pergunta?
Pontuação 12
3 comentários
What a wacky problem!
por
It happened to me too. Its on my iphone 5c. When I push home 3x I get camera. Any suggestions?
por
I found that screen in settings. Thank you
por
Adicionar um comentário
6 respostas
Solução escolhida
Is the screen actually in black and white or could it be that its in reverse black on white contrast mode http://grab.by/Zgb
if it's the latter you can find the accessibility settings in your iPhone and turn it off.
Esta resposta foi útil?
Pontuação 9
4 comentários:
Stitchrobot - You're awesome!!
por
which one is the home button?
por
What is the home button?
por
Mine is doing this but I have a Google Pixel 2
por
Correct answer in my situation… Press the home button three times in succession and it will bring a menu option that says
"voice over"
"Invert colors"
"Zoom"...
You will most likely notice that the "zoom" option is checked… UNCheck this option and your screen will go back to colors!
Yea!!
Pontuação 6
5 comentários:
Awesome! Thank you so much as this has helped me!
por
Other experts could not fix problem, but you sure did, and many, many thanks
por
Thanks a bunch
por
Great brother,
It worked for me....thanks dude !!
por
Thanks I learned something New Today
por
tap your screen 3 times with three fingers. A menu will pop up. Touch choose filter and set to none.
Pontuação 4
1 comentário:
Omg thank you so much! Todd Ramsey ☺
por
looks like a cable issue to me (connector) - unless it's a broken screen.
But hey, colour is overrated !
Pontuação 3
I have LG Aristo that suddenly turned black/white
I tried everything, turning it off and back on, adjust settings, searched internet for help, etc...
Nothing seemed to work
)))UNTIL(((
I pulled down the screen at the top which give notifications and at the very top has signs of features that can be turned on and off by touch.
ie: WiFi strength, Sound, Bluetooth, Location, Rotation, Sync, Flashlight, Airplane Mode, Data, Battery Saver, Color Inversion and "COMFORT VIEW".
Clicked on 'COMFORT VIEW' and (((POOF))) everything went back to color.
Felt like I was in Wizard of OZ. LOL
Hope it helps fix your issue.
Have a GREAT Day!!!
Pontuação 1
1 comentário:
This solved the problem completely!
por
On the LG XPad 2, I pressed the Hot Key once and that put it back to color.
Pontuação 0
Adicionar a sua resposta
Mytech será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 49,534
