Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1502 Perguntas Visualizar todos
Replaced back cover, now screen doesn't work
Hi,
I have an Iphone 3gs 32GB, and I replaced the original back cover which was covered in scratches, with a new back cover.
After I managed to get that done with one of the guides on this site, I found a new problem. The screen doesn't turn on anymore.
I know the phone is working fine and that it's on:
It vibrates and makes a sound and is sensed by the computer when I plug it in with my USB charger.
I think the problem might be that one of the cables for the screen could be damaged, specifically cable #1.
I made sure that everything was plugged in correctly, and nothing is solving my problem.
If cable #1 is indeed damaged, is there a way I can fix it myself inexpensively, What parts would I need?
Or do I need to replace the entire front panel?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Its simple and inexpensive to change the LCD, which is what cable 1 goes to but its not that easy to damage the cable when you remove and replace it so I would make certain it is plugged in correctly, it's easy to think it is when it's not, but if you need to replace it here is what you need, https://www.gounlock.com/details.php?ite..., and here are the instructions, good luck. iPhone 3GS Display Replacement If this answer was helpful please remember to mark it accepted.''
Esta resposta foi útil?
Pontuação 2
2 comentários:
if just the LCD is damaged, would that affect the entire display? What I mean is, would the screen still sense it if I touch the screen?
Thanks for your response
por
To answer your new question, yes, the digitizer would still sense your touch if just the LCD is damaged.
por
Adicionar a sua resposta
Supersayan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 751
