Install an SDD in a MacBook Pro 13" / Mid 2012?
Hi guys,
can i install an SDD in a Macbook Pro 13" / Mid 2012, 2.5GHz model? I search the Guides Section and i haven't found any info on that.
Is it possible? If it is what kind of SDD brand and model would you advised me to buy?
Best,
Esta é uma boa pergunta?
4 comentários
Thanks for the fast reply David. I would like to have a Dual Drive configuration. I will have to remove the Optical Drive then which i think is mostly usless for work.
A fast SDD for the Mac OS X, System and Apps and the original HDD that came with the MacBook Pro to storage music, videos and some files. Do you think that is possible?
Do you know a good brand of SDD? I heard
Cluster
Macsales drive
Samsung (expensive than the rest but very good)
Vertex
Do you know what Apple Fussion is? I heard having a dual drive configuration can be complicated and have some issues regarding software. I hope not.
Thanks again and best,
S.
por uzapuca
Yes it will take a 2TB. But remember to change out the hard drive/IR cable as it tends to be the first thing to failing on this model. Look at the corner of the cable that comes onto the optical drive and examine for any marks or indentations. I put pads on either side of the cable to prevent the lower case from coming into contact with it.
por mayer
Wow, thanks for your swift response. So I´ll try with 2TB and keep fingers crossed for practice.
por Paule
hi @paule2018 w e can move your comments to a new question, this will make your question get up to date attention such as the wonderful @mayer has provided. The original question here is from 2012 and may otherwise be overlooked. Jen
por pollytintop
