Ir para o conteúdo principal
Guias de reparo para o MacBook Air, a linha atual de laptops da Apple.
4805 Perguntas Visualizar todos
Odd keyboard issue after water damage
Right, poured my hot cocoa in the 'return' key area. Was not a lot - immediately flipped upside down and powered off while using paper towers. Waited a few minutes and it worked fine.
A day later, the spacebar and a couple other keys suddenly stopped working. As far as I can tell, no keys are sticky.
Question:
- Would popping each key out and cleaning help or am I wasting my time and risking further issues?
- Roughly how much are we speaking to have the keyboard replaced at Apple?
Thank you.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Apple is always expensive and you should be able to fix this yourself, there is a Teardown Guide here MacBook Air and treat the problem area for the liquid damage with alcohol and a tooth brush or whatever tool would work best, it's not a tough thing to do ! Good Luck. If this answer was helpful please remember to mark it accepted.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ElCapitan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,023
