Pular para o conteúdo principal
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3270 Perguntas Ver todas
LCD Stress pressure marks after installing a replacement screen
I had bought several lcd + digitizer replacements from different seller around eBay. Some of them send good lcd + digitizer replacements and after several purchases some lcd + digitizer replacements have this flaw when applying a little pressure around the lcd + digitizer replacement.
And is that after installing them they will show some stress marks on top and bottom of the lcd + digitizer replacement when applying a little bit of pressure. (Pic Related)
How can I know that a LCD is bad without installing them. I buy bulk orders from time to time since i own a repair shop.
Or anyone has a way to solve this issue?
Respondido! View the answer Também tenho esse problema
Esta é uma boa pergunta?
Pontuação 0
Comentários:
By the way Robert where do you get your Bulk orders ? I have a repair shop too and do the same .
por
Adicionar um comentário
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
2 Soluções
Solução escolhida
This has to do with not correctly cushioning or applying adhesive to the underside of the screen. Mine does this as well and it is a common error when doing it. To get it done correctly try using a small amount of tape and super glue to hold the screen down.
Esta resposta foi útil?
Pontuação 1
Comentários:
Hi Kevin,
Do you mean using tape/super glue during the application of glue or after (when the marks are present)?
How would you suggest avoiding this error when applying the glue?
Thanks so much h!
por
Robert there is a way to test an LCD Digitizer without installing it, first, remove the back cover of your phone, then remove the steel cover plate that covers all of the ribbon cable connection points at the top by the camera, unplug the LCD Digitizer connections and carefully move them out of the way far enough to plug in and test the new LCD Digitizer, there is a (jumper) Ribbon cable made that makes this process much easier, https://www.gounlock.com/details.php?ite... I use it to test every screen before installation !
Pontuação 0
Adicionar a sua resposta
Robert G será eternamente grato(a).
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Todo: 8,607
