Creation of K-Lock Hole
I was thinking about drilling out a K-Lock hole in my iPad Mini. Is there a spot that would be suitable for this? i.e. Is there a spot with enough space behind it to insert a K-Lock?
Esta é uma boa pergunta?
Have you looked at this solution from Kensington: Security Slot Adapter Kit for Ultrabook or this one Kensington Security Slot Adapter Kit
Here's the spec for the slot Slot Spec
The only problem I see is the thickness of the body may not be thick enough to cut you own.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 399
