Ir para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
Why is my ipad not working?
It states on the screen 'ipad not backed up this ipad hasn't been backed up. Backups happen when this ipad is plugged in, locked and connected to wifi' I have done that and its still will not slide open. What should I do? Please help me. Thank you.
Esta é uma boa pergunta?
Pontuação 3
2 comentários
I did who side not working
por
By now I would hope that you have purchased an Android tablet which will do all an ipad will and more but at 1/4 the price. If it breaks down, and all devices can, buy a new one. Then You still have enough left over for about 3 more before you even cover the Apple Expert repair bill.
por
Adicionar um comentário
3 respostas
Solução escolhida
You can try a reboot. Press and hold the 'Home" button and the "ON/OFF" button at the same time and hold them until it restarts and you see the Apple Logo appear on the screen... then you can let go of the two buttons. This should "reset" your iPad and it should work properly.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Thank you so much, it worked exactly as you said, you guys rock!
por
Awesome!!! Worked for me also. Thank you Mendykasr.
por
Some help me my YouTube is telling something went wrong tap to retry when I have my wifi on
por
I've done this before and it worked. How come it doesn't work now? I could only notice that the screen brightens then turns black again
Pontuação 0
1 comentário:
i have this problem too. screen brightens, but no boot logo. I've restored and itunes sees it. Can put it into DFU mode, recovery mode. I expect it needs a front panel and or digitizer? But How to tell?
por
My iPad shuts itself off all the time. Any solutions?
Pontuação 0
Adicionar a sua resposta
Didi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 6,019
