Ir para o conteúdo principal
Model M8413 or A1007 / 600, 700, 800, or 900 MHz G3 processor
36 Perguntas Visualizar todos
break the power on/off socket from the logic board
When i was opening my iBook (here at step 27: iBook G3 14" Display Replacement);
I broken the socket from the logic board because i pulled too much. I used a glue to put it back to the board but now doesn't turn on the computer anymore when i press the on/off button. What I should do no? Pull it off again??? Please Help!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
Answered previously. Ralph
Blue power wire stripped from connector
Esta resposta foi útil?
Pontuação 1
You ruined the logic board you should get a new MacBook or MacBook Pro:)
Update
Its up to you if you wanna fix it you can but thats MY advice
Pontuação 0
1 comentário:
Can be repaired--see Lemerise solution at Blue power wire stripped from connector Ralph
por
Adicionar a sua resposta
Fabrizio será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 978
