Ir para o conteúdo principal
Manuais de reparo e assistência para veículos de passageiros e de carga com quatro rodas.
11707 Perguntas Visualizar todos
How to change oil and oil filter on the Renault Modus 1.2
So I need to change engine oil and oil filter in my Renault Modus 1.2 16V.
Opening the hood there is no apparent oil filter and perhaps I should try to access it from underneath or perhaps take apart a few parts under the hood for easy access in the engine. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hello fellow reno modus mugs yes I bought one last week even if you go onto YouTube for any information the most you will get is how to change a light bulb via taking the front off the car and taking out the wheel arches, the Renault forums are no different ,apparently you need a special tool to take the filter off and its a problem because there is little or no room , does your drivers door drop and clunk when you shut it ? That's considered normal ,just to get to the front strut you have to take off the bulkhead covers and the complete wiper assembly ,these cars are made for dealer only servicing with inflated prices ,one person was quoted £650 to change the cambelt and water pump ,had I have known this before I would never have bought one !
por
It's easy change oil filter: pull passenger side front grill out, drill 25-30mm hole in plastic cover behind that grill or mask. Put tree legged oil filter tool in it's place at filter. Then use several long 3/8 socket rods and push them tru that hole. Now it is very easy to remove or turn filter tight with t spanner outside of car front. After that put piece of tape to cover hole, you can use again in next oil filter change. This is fast and easy way to do it.
I have also change cam belt and water pump and that was quite big job to do.
Pasi.
por
Adicionar um comentário
3 respostas
Solução escolhida
Nick, check the images and see if that looks familiar.
that is for the J77, y D4F, y 740
and the next one for the J77 K9K engine
and here are the drain plug locations
Here is a decent write up. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Hey - where did you find the schematics for j77 - have been hunting high and low for them...cheers
por
I struggled to remove the oil filter but eventually succeeded by making a noose out of some extension flex slip it over the filter from underneath the front of the car again it isnt easy making sure the noose tightens with the more force applied if you have ever used lifting strops you will know what I mean the filter didnt budge until I got the engine oil filter warm by running the engine,you have to be bloody minded.
Pontuação 0
how much oil should renault modus 1.2 16v 75hp
Pontuação 0
2 comentários:
por
1.4 takes 5.0 litres if you change filter too.
por
Adicionar a sua resposta
Nick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 10,781
